hi
i am not able to remove the lock screen wallpaper
i only can change it, but i want to remove it so that the lock screen wallpaper becomes the same as the home screen wallpaper
appreciate your support
thank you
What do you have as you lock screen wallpaper as you could manually add the same wallpaper as your home screen - If your home screen is stock but you don't see the same wallpaper then take a screen shot of your home screen and I'll check my collect of stock Xperia wallpapers I was able to recover via a rooted phone
actually i don't want to use the same home screen wallpaper as a lock screen ... by this way i have to set the wallpaper two times whenever i need to change it and the cropping may not be adjusted the same...
what i want to do is to remove the lockscreen wallpaper ... so that it automatically uses any home screen wallapaper already in use ... btw this was the way it works before i update to 4.3.
I don't think this is possible - I've checked my 4.3 and it can't be done - My 4.1.2 as you have said did use the same wallpaper so I'll assume this is a new feature of the 4.3 firmware
