How to overclock Xperia Ray?
Lets get directly to the point :smileysilly:-
Mobile - Xperia Ray (ST8I)(Urushi)
Build Number - 4.0.2.A.0.62
Kernel version - will provide only if asked
root access - yes (the phone has already been rooted by flashing .42 kernels, using zergrush method and then flashing .62 kernels)
Bootloader - Unlocked using Flashtool
I want to ask that-
1) How can I Overclock my mobile? I have already tried setCPU and CPU master but of no use.
2) Is it recommended to overclock it as it is a compact phone and gets pretty hot while charging! If yes then to what limits?
3) An of-topic question - Whenever i remove my memory card, I loose all the icons of apps installed on my memory card. Is it normal? Anyway to prevent it?
10 REPLIES 10
Nabeel
You will have to search at XDA
foum.xda-developers.com
http://www.google.com/cse?q=overclock+ray&sa=Search&cx=partner-pub-2900107662879704%3Afs7umqefhnf&ie...
3) IT'S normal... no way to prevent
3) is their anyway to automaticaly get the icons back when i reconnect the memory card?
if the apps are on the SD card no you can't keep them in the internal memory
In droid when i remove the memory card the shortcuts remain their although they are not usable (It's obvious). After putting the sd card back the shortcuts remain on the home screen and become usable.
Can any similar thing be done with xperia ray?
so you are saying that when you put your SD card back you can't use the icons anymore?
The icons get deleted so how can i use them?:smileyangry:
calm down, that's a bit bizarre, try a different launcher
I use the default launcher only as other consume more ram. (My experience)
can u please tell me a launcher which use lesser ram.
which launchers had you tried so we don't suggest the same Dizzy_Face
