Hi, just bought Xperia-U.
Imported all the contacts successfully but the problem is that a random no. is appearing in 'Myself' contact and when I try to edit it means add a new no., and mark that no. as default(set as default), still it shows that particular no. only and not the updated one.
Plz help any way out with this.
Thanx in Advance.
Can you delete the number you do not want? If you go to Contacts > Myself > Menu button > Edit, you will find a X to the right of each phone number. If you tap this one the number will be deleted.
