That's standard with Android, not just Sony, perhaps a different home launcher could have that option but again, that's how Android works.
@MrCustomer wrote:
How do I customize bottom 3 virtual buttons? Recent key is useless and I want Menu instead.
You can either settings > apps > select the app > disable
or
Root your device, then you will be able to uninstall the apps, keep in mind that Sony doesn't have as much bloatware as other OEMs
@MrCustomer wrote:
How do I remove What's new, Video and Album? Didn't asked for them and definitely not interested in their annoying messages and pop ups. Furthermore don't agree with terms and conditionst of these apps. Can't be even disabled!
@MrCustomer wrote:
Typical settings widget is missing completely and instead we must use Power Toggles.
Could you elaborate? if you pull down the notification bar you should be able to see iconds, or you can use a widget or a shortcut or download third party apps to just that.
@MrCustomer wrote:
I understand it might be hard to believe for Sony business managers, but if I would like to have no customization and blindly follow manufacturer like sheep, I would have purchased the iphone. I went with Android based phone, because wanted 100% customization and it is not there!
Thanks
I assume that this is your first Android phone, you can customize your phone as you please, you can download different home launchers, lock screen apps, etc, you can make your phone feel and look how you want it. On a side note, Sony it's the closest you will find to Vanilla Android (found on Nexus devices).
I don't know which other phones you had before, but if you pull down the notification bar you will see icons that will turn on/off different things such as WiFi, Bluetooth, GPS, LTE, etc.
as for what's new
settings > apps > what's new > permisions (no permisions requested)
Notifications turn them off
open by default leave it blank
Also, you can download a different app to freeze it.
