i have updated my sony xperia s to ics and i want to connect my phone to pc via USM
because it has only one mode MTP which is very slow...
you can't connect your phone as MSC or anything else other than MTP
You can connect Xperia S in Mass Storage mode, but this requires to root your phone and install special app (I believe it called SDMounter). But you shouldn't do this if you are not an experienced Android user, cause if you do something wrong it could brick your phone. And I believe rooting will also void your warranty.
rooting doesn't void the warranty, it could if you damage your phone while rooting it.
