I've been waiting for the update for my SI 1250-3615 and now the end is on the list, the experience with my Mini Pro is very good, battery lasts 2 days, with wifi, whatsapp, gmail, hotmail, calls and this is good, also the performance of the phone is good too, now have Android 2.3.4 (when I buy what I had installed), so if I have the latest version of Android, but I do not get to have a bad experience just to update it.
With ICS the battery will last less? The performance will be less? or? I can reinstall 2.3.4 on my Android phone in a simple way without losing the warranty?
Thank you.
you can downgrade to 2.3.4, you have 2 options
1 take it to a sony repair center
or
2 manually downgrade
http://talk.sonymobile.com/thread/38251
battery life depends on what you sync w/ your phone and many other factors, an advice don't use antivirus, taskillers and/or battery apps as they drain your battery a lot faster and create a lot of other issues
Do not use antivirus? I use avast? necessary? I do not use anything other than mentioned.
With PC Companion can do that? o with SEUS
you don't need antivirus, this is android not a PC
as long as you download apps from the market and you check the permisions each app requires you'll be fine, an example
if a livewallpaper require to read your sms/mms phonecalls etc that's something wrong with that app
don't install it
you can use SUS or PCC either or
Update Service (SUS)
Ok, thanks very much, for your information, I going to test ICS and only wait that this work very well.
anytime let us know if you need any more help
