Just got my Xperia XP phone and setting up everything.
Is there any chance to change the Clock display format
Something similar to the clock in the picture
You have more than one type of clocks to add on your home screen. Tap longer on the screen, select widgets and clocks.
alexdon,
Thanks for the quick reply
That clock looks smaller than the lock screen clock
Is there an option to make that clock display bigger
Hi @HandyCam,
There is unfortunately no setting to increase the maximum size for the clock widgets. There might however be other options available in Google Play where the option to increase the size of the clock widget is possible.
