Hello,
I am facing too much of heating sensation on my xperia l since it has come from sc after repair...is 30-35 degrees of temperature ok in idle or light use condition? And when i charge it it goes to 40-44 degrees is it ok? Plz guys reply fast m very scared about this..i dont use any case..this temperatures are without any case..plz help
This is normal, the more or longer that you use your phone the hotter it will get, if you play heavy demanding games (most games are) it will get hot fast, same goes as when you charge your phone.
Don't forget to give Kudos
What are the ideal temperatures for Xperia L? Can you list them?
mine roll around 30-37 in idle n light use state
These are good temperatues for a slim smartphone with dual core processor
A lot of competitors (like S2 and nexus that i tested) can reach battery temp of 50 degrees or above during normal use
There isn't a specific range of good temperatures because are influenced by environment, apps used, hand temp and antennas enabled (GPS, 3G...).
In my opinion the following are very good temps:
- Idle mode: under 40 degrees
- Normal use: under 45 degrees
- High use (long 3g session or 3d games): under 50 degrees
