help
j19
help
ive had my sony xperia j for a while now recently turned off one days, but still is coming on like it normally does such as says sony, then xperia and goes to the o2 then just turns itself off, any one know the reason for this?
5 REPLIES 5
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable.
alexdon
j19
there is pictures and everything on it off the kids that i dont want to loose, so what should i do?
Try this, remove both the SD and SIM card > turn it on > wait until you see the O2 logo >  connect the phone to a wall charger > see if that does it
j19
no it didnt work just went back till loading the phone when it turns on
thanks anyways
Sorry to hear that
