1 Contact your carrier as its up to them to approve and release the update
2 that's a network 4G coverage issue, contact them
4G is disabled on 3 until you update. Others have posted on here with exactly the same problem.
You can either wait for 3 to get round to releasing it, or you can manually update yourself:
You could create a backup of your current firmware
If you follow the steps on XDA you shouldn't lose warranty as you don't have to unlock the bootloader or root.
You will still get future updates from Sony, but be aware that if you flash, say, the Australian firmware, you will get future Aus updates. If you back up your original firmware as described, then you can of course always re-flash and get UK updates again.
Before you do anything, it might be better to go back to Currys and ask them if it's only a couple of days old. You could change it for something that isn't Sony and actually *is* 4G ready out of the box.
OK some news.
I managed to manually update to 4.3 without routing or boot unlocking, I kept everything stock. So here are my remarks :
1: Even though I read many negative things about 4.3 , it seems its working perfectly fine for me, although at the beginning it feels a bit slow and lagging slightly byt as the time passes I have the feeling that it gets smoother...
2: 4G works now!
3: I downloaded a Greek version ftf as I am Greek
I suppose that's not going to create any issues?
Well unsurprisingly so far so good!
I take it you went with the .201 build that came out this week - that one's OK. It's the earlier .266 that many people had problems with.
I does get smoother after a couple of reboots.
But, cool - you now have 4G.
Yes its 201.
Hmm it seems ram usage is a bit higher than 4.1 sits around 75% compared to 60% I had in 4.1.
