Iv been messing with my new phone as i usually do and gone onto accessibility and put on the talkin mode on my c1505 but it was annoying so iv gone back onto settings and tried to scroll down to accessibility but it wont scroll!!!!
can any1 help so i can get it back to normal please
That's odd, press and hold power & volume up for 5 seconds and try again
Xperia E does have that problem. Once you turn on talk back, it is a little difficult to turn it off. If you don't care about the phone's settings and you have time to set them again, you may reset the phone to its factory settings. But if you don't want to reset your phone, then you will need some perseverence to turn the talk back feature off.
Its not difficult dont panic and xperia e has no isue about it be patient to turn off this feature, she will reapet what u do slightly slide the button to turn it off it will get turn off no worries
Ok I replicated this on my Xperia M and it seems like you can't scroll down when you have the Explore by Touch setting enabled in TalkBack settings.
To switch it off.
Unlock your phone by dragging the slider with 2 fingers
Double press the menu key
Swipe your 2 fingers left/right to get to settings
Double tap on Settings
Scroll 2 fingers down to go to Accessibility and double tap it
Double tap TalkBack
Double tap the switch
Hope this helps.
Yeah it isn't a problem with xperia E, it is rather the way the talk back feature works. I didn't know that before.There is a tutorial available in the phone itself at Settings-->Accessibility-->TalkBack-->Settings-->Launch "Explore by touch" tutorial.
With talkback feature on, you have to use two fingers to scroll down or up a page, and use double tap to select an object.
