everytime i receive a message from this particual contact, it appears on the icon saying 7 messages however when i try to have a look at the 7 on that contact it comes up blank?! i cant see any of the messages and i cant delet the contact who the messages are from. ive tryed turning off my phone and deleting but nothing works!
i wouldnt recommend anyone to buy a xperia x8 they are rubbish!
Hi, are you using the stock messaging app?
It sounds like you have some corrupt data in this particular message thread. As you cannot delete this thread directly it would be worth running a repair via PC Companion to remove this corrupt data.
Make sure you backup everything
Backup & Restore app
Use this links to download the apk
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkhttp://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
