help
help
hello i am sorry for my english because i am french
but I installed in applications "water level" but I was unable to open or remove a
how should I do???
answer in French if
3 REPLIES 3
Dr_Chris
Delete it and re-install it.
no because is not posibole delete !!!
What for ?? i dont no
Dr_Chris
If the application was downloaded and not pre-installed, then you should be able to delete it.If you cannot do this and the application is on your memory card, take the card out and use a USB card reader to delete it on your PC.If again you cannot delete the application, back up your memory data into the PC and format the card.Then put the card back into the phone and download the application again.What happens now?
