Hello Guys,
I'm an Xperia tipo dual user, with current build number 11.0.A.6.5 updated using Sony PC companion. I just want to ask, does the tipo dual have physical RAM of 512 MB? That's what I thought before, because when I checked my Ram it only has a total of 404MB, wheres the other 100+MB? I'm very disappointed cause I hav to use memory booster or task killer so it won't lag. pls.help. 😐
here are the screenshots...
I'm also facing this problem
and waiting for explain and solution
The phone has 512MB RAM but some of it is used by the system so when you check available RAM you will not see the entire 512MB as available for your apps.
