Daylight saving just started and all my calendar entries have moved forward 1 hour!!! Can I fix this? How???
If you go into Settings--General--Time and Date--My Time zone: If you change/deselect whatever city is selected, you can stop automatic update of daylight saving changes.
Thanks Dr Chris
Is there any way of switching back once the update has happened?? My whole calendar is out by an hour!
Well, you can manually set the time to the current daylight saving if you have switched off the automatic time zone setting.Also, see what is available in the calendar options.
