i can't use my android beam with other samsung galaxy s3 to share any thing
from or to my phone
my phone redirected to play store every time i tray to use this feature !!!!!
even after i turn NFC & Android Beam ON ......
model number : LT26w
Android version : 4.0.4
build number 6.1.A.2.55
•Make sure NFC and Android Beam are activated in both phones.
To turn on the NFC function
From your Home screen, tap .Find and tap Settings > More….Mark the NFC checkbox.To turn on the Android Beam function
From your Home screen, tap .Find and tap Settings > More… > Android Beam.Tap so that changes to .
•Hold the phones next to each other so that the NFC detection areas are within scanning range. When the phones connect using NFC, they both vibrate and the file transfer starts.
NFC detection area
The location of the NFC detection area in a phone can vary depending on the phone. You can swipe an NFC tag against the back of your phone to detect where the NFC detector is located. For more information, refer to the User guide of your phone.
•Make sure that you use the Album application when you transfer photos to another phone.
•Make sure that you use the Xperia™ Walkman™ player when you transfer music to another phone.
•Make sure that the Home screen is active on your phone when your phone is receiving files from another phone.
•Transfer one file at a time.
•Check that the other phone has full support for NFC.
didn't work
so what can i do nowwwwwww
