my screen automatically turn on even after i lock it mny battery is draining fast because it wont go black unless i lock it again then after a few seconds it will turn on again even if i didnt touch it! help!!! my screen time out is in 30 seconds mode
do you have a protective case w/ this phone?
1) backup everything
2) repair your phone with SEUS
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
Use one of these links to download the
Backup & Restore app
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
How to install it
You need to
download IO File Manager
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
My Phone Explorer
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&hl=en
An easier way to install the Backup & Restore app
download the apk on your computer, send it to yourself through email, make sure you send it to your Gmail
now on your phone
wait for the email, once you get the email, open it, and instead of downloading the attachment it will allow you to install it, voila, done
or
if you want to manually update your phone
Xperia X8 2.1.1.C.0
http://talk.sonyericsson.com/thread/29293
So if you lock the display and leave the phone lying on the table, not touching it - it turns back on?
Is the phone connected to a charger or via USB to a computer when this happens?
or maybe a case protector that might be pressing the power or Home button(s)?
