Keep us updated
HI lottie13,
Discussion Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines
You may also want to check the SIM card or SD card, as they could be causing these issues. I suggest removing the SIM first and try using the handset and see if the issue continues, failing that do the same with the SD card.
You can also boot in to Safemode, this will stop all third party apps from running and will let you know if the issue is related to third party software.
