help my w910i main buttons not working!!plss help!!
Main buttons not working!!
"NOT WORKING" left soft key,answer button,end/standby button,delete/C button,Pop-up/menu button....
WORKING buttons arrow keys and select/play key,numbers 0-9,#,*...
help me!!
what should i do...??
6 REPLIES 6
Dr_Chris
Try running the SE Update service on your phone and see whether this restores functionality.
its me pitty...sorry i forgot my password..
i've try to update my phone...but the proccess needs to hold/press the button C/delete..
but my C/delete button...is included in not working/malfunction button...
what should i do??
Dr_Chris
Then contact SE, if your phone is unusable.
Pitty, I have the same problem as you. Though I may have a solution(if you havent thrashed your phone), i am working on it now. All buttons on my phone are not working except the keypad.
I'm having the same problem - this has to be the worst phone I've ever owned. It still randomly cuts out as well, but right now I can't even get it to start...Ben, did you have any luck with the fix you thought you might have?
dandavey
Did you ever get any luck fixing this problem?
