HELP: My Sony xperia sola can not re charge and is not get start.
Ali007
HI
My sony xperia can not charger after recent charging of battery finished. When I tried to connect with USB PC charging it just
show for a while red LED and then SONY logo but then again went off and dark screen come up with no response. Same problem I am seeing when I tried to re charge my cell with regular Charger.
Urgent help required.
regards
Tags (1)
10 REPLIES 10
Try this
1st connect the phone to a wall charger > press and hold power & volume up for 5 seconds  (while connected to the wall charger) > let it charge for 1 hour
2nd repair your phone with SUS or PCC
Don't forget to give Kudos (Click on the half star + )
Ali007
appreciate your reply. i can not have wall charger at the moment. So can i do same steps for charging with PC USB option?
And other question is how it will detect my cell by using SUS repair as if  still it will not get on by then too or phone would be still dead at then as it requires 50% charge up ?
I don't know if that its going to work (using a PC instead of a wall charger) you can try
shihstouch
Enthusiast
Normally PC doest have capacity to boost your battery because it has a low out put power compare to wall chargers, you should find a wall charger, or take to any mobile service centre ask them for boost your battery, most of them do it for free...
Ali007
I did all options PC USB CHarge also  with regular charger.. but after couple of hours my cell is still dead. Only same situation when i put on charging . it shows Few seconds red LED and then Sony logo then dead. Also when i do repair from SUS or PC Companion it do not detect phone as it is dead. Please give solution which can make re start my cell
Ali007
And now is no any kind of response from my cell phone even try to charge either by normal charger wall or PC USB, even no LED response. IT is now completely dead.
shihstouch
Enthusiast
If its a battery problem it should pick up...
If nothing works send to Sony Service Centre immediately...
Ali007
You mean sony service center?
