Hello Friend
I met a real problem: (
I had no problem when I bought my smart phone and smart phone I've successfully updated
Unlike the Android 4.1.2 smartphone to Android 2.3 back chair back, but now I feel like my phone battery is too weak or too fast is empty: (
What strategy would you recommend for me?
And the only other way is to calibrate the battery?
Restart your phone (power & volume up at the same time for 5 seconds ) and if that doesn't work, re-install the update all over
I like what you said but I do not: (a screen name not open recovery Should I install the software?
That is the only way to repair the battery?
That's only if its a software issue. if that doesn't work then you will have to stop by a Sony repair center
Backup and Restore, but even when I set the phone to clarify not just
I don't quite understood that
Why do not you answer?
