Good all
Ratillo ago I was changing rom when it occurred to me the brilliant idea of format (system , cache and data) , and it turns out sa PETA and I had to remove the battery.
Total I started believing that I could enter my recovery but I was wrong, but I give it does not, all I've been to pc companion pa repair because it happens to me the logo of sony, and it does not recognize my usb cable I've tried several ports and two different cables , neither work for me in the flasthool
HELP not to do
I tried it with 2 cables, and several usb laptop and when I put it aside to charge current, I do not get it from charging, or the led , just dive in without encendese sony nor stays off
connect the phone to a wall charger > press and hold power & volume up for 10 seconds > let it charge for 2 to 3 hours even if it doesn't show signs of life.
I test it and tell you .
And for my pc to recognize my phone
Do you know anything
Not recognizing usb
Flash tool and PC Companion
not working
You will have to contact your local xperia Care
sony assistance does not help me in this, puts nothing
Why aren't they helping you?
