HELP HELP.....!!!!!!!!!! My Xperia P isn't charging.......
aatoo123
My phone isn't charging.....I reeboted it a several times but the battery is draining even if the charger is plugged in....please help......
6 REPLIES 6
chumpchang3
Try using a USB cable with a computer.  If that doesn't work, try a different USB cable.  If that doesn't work, your phone has a loose port which means you'll need to bring it into a service center.
aatoo123
It's connected to my computer but still the battery is draining......Also while charging throgh power supply, the LED glows but the battery is still draining.....
ryan515
Repair it with SUS or PCC. and if that doesn't work. bring it to your local sony service center.
profile.country.RO.title
_alexdon_
shut down the phone and let it stay a little,then connect charger and turn onn the phone and let it charge.
alexdon
DroidReuben
Everybody! I know what this problem is! if its plugged in and the led is lighting up but the battery isnt charging and is reducing, it means the charging out put is too weak, my home wall socket is the most powerful charge out put for my phone there for i alway plug it in there but i have noticed by chrging it through a usb cable and computer or something like that, the out put is too weak, you will have to such for something with a high electricity out put (try different sockets around the house) if still nothis, visit the repair centre, I WISH WE COULD CHAGRE OUR XPERIA P WITH A WIRLESS NFC CHARGER OR SOMETHING Slightly_smiling_Face
florenzgonzales
are you mad bro?
