HELP - Emergency calls only!
hollyguto
Hello guys, I'm creating this topic because I haven't found anything helpfull so far on the internet.
Well my problem is, my Xperia E dual is not showing any service for my main service provider, it is stuck on the emergency calls only.
I am from Brazil, and and have 2 SIMs, one of them is from a service provider called TIM, this is the one with no service. My other SIM card, however, is working perfectly, it is from a service provider called Oi.
Well, I'm pretty sure it is not a SIM's problem becase I've tryed it on other cellphone and it is working.
So far I've tryed to do a hard reset and run the repair tool from Sony PC Companion, with no luck at all.
Another thing that might worth mentioning, my xperia recognizes my frinds numbers saved in my TIM SIM, (in other words it recognizes the SiM itself) but has no service.
Can someone enlighten me?
Oh, my cellphone still has warranty by the way.
Thanks in advance!
9 REPLIES 9
profile.country.RO.title
_alexdon_
Try to use first SIM on WCDMA/GSM and the second on GSM only.See if that makes any difference.
alexdon
hollyguto
It didn't work, and neither the other way round (2nd chip on WCDMA/GSM)
_alexdon_
I think you should visit a sony service:
alexdon
Jake-SonyXperia
HI hollyguto,
With the information provided, I can advise that I agree with Alexdon, the handset needs to be checked by a service agent, however before you perform this task, I suggest that you back up the handset first.
Please use the link below to find out how to perform a backup.
Backup & Restore
I apologize for the inconvenience this may cause.
What are your thoughts about this forum? Let us know by doing this short survey.
hollyguto
Ok, I'll keep those things in mind
Thanks in advance
Jake-SonyXperia
No problem, let us know how you get on with the issue.
Stanly_CK
I got this problem too last January, but I brought my phone to the Sony Centre and they fixed it for me Slightly_smiling_Face
Something to do with the hardware if I'm not mistaken. Because I dropped my phone a few time before.
Not sure about you, though. Good luck.
Tags (1)
Stanly_CK
I got this problem too last January, but I brought my phone to the Sony Centre and they fixed it for me Face_with_stuck-out_Tongue
Tags (1)
hollyguto
Well, after not solving my problem I called in the warranty and send the phone to a sony center.
My problem is finally solved ^^
Thanks for all the support guys
