f now it's showing 1 day 6 hours on charge above 90& **bleep** it was previously showing above 3 days battery time why is this....?
The time is based on useage over a period of time so for example you don't use it apart from calls and sms messages then the remaining time will be high - The if you play games or use it for GPS etc then the remaining time will drop besed on recent usage
On a side note watch the beeps (Language) or you will find yourself with a warning
To reset stamina mode,do this: first disable it,after that go to settings-apps-all-eco mode controller,force stop and clear data.Restart your device.
If eco mode controller is not there,look for extended standby.But search better and get rid of any task killers or battery savers.
