Help about animated background
Meid
Hello, I need to know which is the resolution of pictures to use animated background with my owns pictures. Because pictures goes dark and not aligned!!
7 REPLIES 7
ogu
Hi Meid
Try this link
http://www.phonearena.com/news/How-to-make-wallpapers-optimized-for-Android_id31322
If you want to know the exact res it should be 1440x1280 pixels.
When adjusting the picture I generally use google's Photographs app (Not sure about English name) it automatically takes the max size possible and aligns the resizing window right in the middle.
Meid
Sorry, I don't understand why you instead to me writing to support Sony
Meid
Yeah, in Spain is Fotos, same as Photos or Pictures, but the problem is that I can use Google fotos every time, but when I must choose pictures to do my own animated background, I can only choose photos, and not aligned or resizing!
What I mean is:
Go to
Adjust
Screen
Background
Animated background
The last option, under all animate background is to choose your own picture
And you can only choose picture and choose transition time till 20 seconds
So in my background I can see all pictures, but they are not like I want, just I think Xperia resizes and align like Xperia wants, and other problem is it shows darker than original
ogu
Ok, sorry Meid I misunderstood your issue. Now I see what you mean.
In animated backgrounds list I have something called photo slideshow, when I choose it it previews how it'd look, just like you said it is a little darker on the top. I think it's just an effect. And it zooms in to maximum height and cuts the sides. I don't think users can adjust which part of the picture to show, it just shows the middle.
If you hit the slideshow settings on down-left, three options appear, the second one is layout (or should be something like order/style) A pop up appears when you tap layout. You can choose fullscreen, medium, small. Medium one fits all of the pic to the screen but shrinks it down to do that. Maybe it'd suit your needs.
Meid
I don't mind that, I should like to know if it is possible to do in PC a correct size (and what it's the size) to show the part of the picture I am interested, and the another thing, it's that the pictures show very very darker as original as animated background!
ogu
Xperia SP is 720p, if you crop the pics to 720x1280 (Or any size with 16:9 aspect ratio) it should fit in the whole screen including the back of navigation buttons and status bar. So if you want it to fit perfectly it should be 720px in width and 1280px in height. On the other hand any other combination should also work as long as width stays equal or less than 720px and height stays equal or less than 1280px.
Edit: Sorry about that. Like I said any resolution with portait 16:9 should fit but for other aspects I am not sure. The size should be something that fits in 16:9 so the width and height ratio should always be within the bounderies of 16:9 ratio.
I don't think you can do anything about darkness. I think they've put that effect to make sure the icons were visible enough.
You can also search in Play Store for photo slide show live wallpapers. Maybe a third party one would suit your needs best.
