Heating problem in T3
aksood
Whenever i use my xperia t3's chrome or camera the device heats quickly on the upper half and around 65% RAM is always in use even when no app is being launched. PLEASE SOLVE.
Tags (3)
7 REPLIES 7
Hampus
By the information that you have provided it does not sound like a problem.
There is a difference between heating and overheating. It's completely normal that the phone gets hotter while it's in use and depending on your configuration/apps that are active in the background, the phone may get hotter than normal. This may also occur when you charge the phone.
aksood
but it goes to around 50 C in temperature and around 65% RAM is always in use. why is it using so much RAM even when no app is being used. Are there so many background processes?.What happens if I run a heavy game like aspalt 8 . Will it run in 45% RAM??
Tags (4)
Sangeeth47
My T3 Heats Upto 68° ... Then 50° Less.
t3user
They better get things in order or otherwise they are going to to loose whatever little hold over the market they have. I mean faulty products... overpriced too!!!!
t3user
I went against all the negative comments which I came across while reading user reviews. I couldn't get my head to think straight and really was wondering that not every set could have the same issue but really feeling bad abt this now. Loyalty to brand is not everything.
t3user
Had xperia x10,camera was good fell in love with the mobile and eventually the brand.
Wanted aa good camera mobile but really got disappointed
amit_rocking87
how can you confirm temp. reaching 65deg ??.. please post screenshot with measured temp.
do you tried factory reset or phone repair option ?
