Headset problem
ezhikov
Headset problem
Hello to everyone.
Yesterday i bought new headset and it works fine, but today my sola can't recognize it?
I tried in on few other devices like iPhone, HTC Desire and iriver music player and it works. What is wrong with my sola?
After repaib by PCC headset worked some time, but then, after reconnect, it is not recognizable again. Maybe this is LiveWire Manager issue?
11 REPLIES 11
Markus1
Leader
Go to Google Play Store and search for LiveWare manager. If there's a update available, install it and then let me know.
ezhikov
The problems began with version 3.3.10
I did a factory reset and did not install the update. Currently version 3.1.13 and the headset works.
After reconnecting the headset, it has ceased to be recognized by my phone. Now I'll try to update and write to you what will happen.
ezhikov
after updating the headset does not work
ezhikov
When I get a solution to this problem? Maybe next year?
ezhikov
Should I wait for your answer, or just throw the phone in the trash and buy a new one?
gharika
What is the model of the headset that you bought? Atleast it will help others to avoid that headset if Sola has compatibility issues with it.
Does the standard headset work with your phone?
ezhikov
"Skullcandy ink'd 2" and standard sony headset and nokia headset. before updating to .184 and updating live manager there were no issue.
gharika
It would be wise to let one of our authorized service shops have a look at your phone. It seems like a problem with the phone itself if none of the headsets are working. Also, please note that Sony Xperia phones use a different standard for 3.5 connectors and though the jacks looks similar, they may not be compatible, though this is not the case for you since it worked first time around. My iPhone headset does not work with my Sony Xperia Sola but when I connect it using a Extender cable I have for Sony, it works fine.
ezhikov
If headset have compability problem, so why it works sometimes? If it works fine before update, so why it should be hardware issue?
