headphones problem
njviln1
headphones problem
When i use M2 to play Music i quite ofter use Headphone, but when i do the Music keeps pausing for no reason whatsoever, and then starts playing up again. Sometimes it can pause for over a minute, most times it last about 1-5 seconds.
This only happens when i use my Headphones. Playing without my Headphone, it plays perfectly. I have also tried another pair Headphones, and it still does the same..... So does this happen any other user, and does any person know how to stop this from happening?
4 REPLIES 4
rajanv
Did you try with another headphones or even wired speakers with 3.5mm plug?
You can also try Settings -> Apps locate Walkman app and try to clear the cache. Then check the headset. Does same problem occur with FM radio?
njviln1
I have tried the FM Radio, and that works fine.
I have tried 2 more headphones, and i still keeps pausing for no reason.
I have already cleared my Cache in the Walkman App, and i still keeps pausing.
I have not tried wired speakers with a 3.5mm plug, but i assume they would do the same as the headphones.
Stuartyc
I have the same issue is there a fix other than sending the phone for repair?
tulipan
I have the same issue. I think its sdcard reader error... When i play music from internal memory its ok.
