Headphone
sakurka
Headphone
Hi, I have problem with my SE Xperia PLAY because my headphones is damaged so i have a question: I buy the headphones to work me on this phone,
I plan to buy earphones but apparently can not have a microphone to work, you can tell me if these headphones as Natec Eagle can I use?
Frequency response: 20-20000Hz Headphone Efficiency: 110 dB
Connectors: jack 3.5mm
Alexander1
To get your headset to work with your Xperia Play you'll need a headset with the OMTP standard. You can find more information about the difference standards if you check the following thread:
http://talk.sonymobile.com/t5/FAQ/Problem-using-headset-accessory-not-supported/td-p/347872
