headphone jack not working problem continues on my Z3 phone , Z3 Tablet.
Curnow1
I've once made a thread about my 3.5mm Jack on my phone , a green coating was on the jack and it didn't work. This time its on BOTH of my devices. The jack only works after rinsing it with water , only then i can connect the headphones .
I've did everything
Blowing inside the jack ,
Tried Cleaning the data from Smart Connect
After the jack dries up from water , the headphones disconnect and i am unable to connect it again.
15 REPLIES 15
mr_xzibit
Get some ear-buds and some vodka. Soak the bud. Squeeze away the excess. Insert and clean.
The green sounds worrying. Copper turns green when it oxidises. Perhaps a protective layer has been removed somehow?
Seek help as unless you get it sorted the green will continue to return.
Thommo
Genius
I agree about the green and copper link
Curnow1
Mister,  thanks can you tell me what do you mean by oxidises? I dont know English well because im from poland 😕
Also 1 problem has acquired while clcleaning it with vodka,  my jack is probably totally destroyed now in my phone. While cleaning it 1 of the top parts of jack came off it like snapped from the hole metal parts,  it was all green and only some metal parts were visible. What to do :(?
Curnow1
Ahhhh accidentally accepted as solution cuz im on my tablet now. How to unamrk as solution???
Also if we are talking about some protective layers well my tablet went into a hot bath with soap but only for 5 seconds because i took it out stright away and letted it dry. I had a z1 it never happened
But my phone was never in water due to a crack at the corner and im not sure about the waterproof ability.  but i have a 2nd z3 and it was in water but both my z3 phones and z3 tablet have this green coating
mr_xzibit
Curnow1
Ill read it in a min here is a pic
https://www.dropbox.com/s/zv7f2zzb0vk26se/DSC_0507.JPG?dl=0
Thats my tablet,  i cant make it of my phone cuz like i said the top part snapped off
Thommo
Genius
Definitely looks like oxidization - It's like rust only green because it's on copper
Curnow1
So what can i do with it 😧
Is  it my fault or happened it self
And how could that happen,  how the protection came off?
Curnow1
Anyone reply how could this happen and is it my fault or i can go and ask for warrenty repair?
