HDMI for xperia mini pro
Just do this simple test and you will understand why i'm saying this. Dial *#*#7378423#*#* go to service tests-hdmi test it works ,even shows the settings,then try infrared test (iRDA) it won't work as there is no such function. This proves that it supports HDMI. Sony should look into it.Thanks in advance for any support, I need help Slightly_smiling_Face
profile.country.PH.title
MarlonUk1
hate to burst your bubbles right there bro, AFAIK,  these settings are indeed for hdmi, but not the one you'll have to connect via hdmi cord as you can see there is clearly a hadware limitation for that, this is used for viewing via a UPNP server, where you can share media to a HD upnp capable device such as a HD TV via wifi,see the connected devices app on your menu. :smileygrin:
