Hi Guys,
I have installed a build.prop and a bootanimation.zip on my Xperia. I found it on XDA Developers' site and it said it is compatible with my phone. I tried to restart the phone, but there isn't any bootanimation, and it doesn't turn on after minutes too. It doesn't have any recovery, and I can't restore the software with the Update Service, and with the Sony PC Companion too. And I tried it with Flashtool too, but I wasn't lucky. Please help me how to bring it back to life!
(Flashmode is working well, but the computer can't install the drivers for it.)
Are you running a 64bit system or Win8/8.1 if you are then try running Flashtools in compatibility mode or use another system running in 32bit like Win7
Thank you Thommo,
I fixed the problem. Finally I could flash a firmware with the flashtool, then I upgraded it to the lastest. Now I have root access again, and I installed the Clockworkmod recovery too!
I have made a lot of backups now, so I can restore it, if need to do it.
Thank you again,
Best wishes
VA3KAMA3
