i have a problem wich is the signal of gps is bad
it take at least 10 min to catch satalite is that normal or i can make it better
thnx
Sorry to hear about the problem with the GPS you've faced.
What software does your phone run on?
There's a new version of software rolling out as we speak for Xperia P, you can read more about it on the link below.
i have ics
and the same problem
i readed in fourm that i shall change file in the system to make the signal better
the file is gps.conf
it's in
system > etc
it wrote in it
the original file
SUPL_HOST=supl.sonyericsson.com
SUPL_PORT=7275
the other one
NTP_SERVER=0.za.pool.ntp.org
NTP_SERVER=3.pool.ntp.org
NTP_SERVER=2.pool.ntp.org
NTP_SERVER=ao.pool.ntp.org
NTP_SERVER=mg.pool.ntp.org
NTP_SERVER=0.africa.pool.ntp.org
NTP_SERVER=1.africa.pool.ntp.org
NTP_SERVER=2.africa.pool.ntp.org
NTP_SERVER=3.africa.pool.ntp.org
XTRA_SERVER_1=http://xtra1.gpsonextra.net/xtra.bin
XTRA_SERVER_2=http://xtra2.gpsonextra.net/xtra.bin
XTRA_SERVER_3=http://xtra3.gpsonextra.net/xtra.bin
INTERMEDIATE_POS=1
C2K_HOST=c2k.pde.com
C2K_PORT=1234
SUPL_HOST=FQDN
SUPL_HOST=supl.google.com
SUPL_PORT=7276
SUPL_SECURE_PORT=7275
SUPL_NO_SECURE_PORT=3425
SUPL_TLS_HOST=FQDN
SUPL_TLS_CERT=/etc/SuplRootCert
ACCURACY_THRES=5000
CURRENT_CARRIER=common
DEFAULT_USER_PLANE=TRUE
REPORT_POSITION_USE_SUPL_REFLOC=1
shall i do this change ?
Confirming very weak signal too...I have lastest ICS and using Sygic GPS...yesterday I was not able to lock gps in big city where i was lost, I almost hit my xperia on the ground!
i have the same problem
it's signal is very weak :S
