Hello Sony and other users
If updated my Neo last week from the stock firmware to 2.3.3 build 4.0.A.2.368.
After that I have issues with GPS signal (DOP). Programs like RunGPS, Google Maps and Navigon loses GPS signal exactly every 5 minutes für about 30 seconds. After that, the DOP is good again. Sometimes it helps to restart the phone, sometimes not. I've tried to find out if it depends, which programs are in the memory but nothing is really obvious.
The issue looks like this:
Yesterday I've updated to 2.3.4 4.0.2.A.0.42, but the issue is the same. I've read in another forum that sometimes an update of Googe maps could cause this problem. So I've deinstalled the last update of Goggle maps. Before that I had this issue, directly after that it was gone, but it came back although I did not install the update of googe maps again (Auto update was disabled).
Before the firmware updates I did not have this issues.
What can I do? Are there some log files, which can help? Any idea?
With this issue the GPS is not really usable. Is it possible to downgrade?
Thanks
If the team I escalated to needs more info I'll make sure to ask you for it. Good to know you're willing to help us if we need more info. Thanks for this!
I'm eagerly waiting for ICS too. I think it will be boss!
Just like to add that I have the problem when my DATA is turned off. When I switch DATA on again, I will still loose GPS again when the 5 minutes is up the first time but after that GPS seems to behave ok. But this is not a solution because I like to use my GPS without DATA.
Hello,
I got exactly the same problem !
Cheers
your suggestion were great.
I didn't notice that i have any problem with the gps.
I was using navigation extensively, and i set according to what you have syggested.
just out of curiosity, go to settings -> location & security -> what do you have selected?
Use wireless networks? YES
if you have this selected, did you allowed Google to collect anonymous location data?YES
use gps satellites? YES
I could not see any disconnection with GPS on my ARC -S.
Since it works, i didnt bother to see if i set it back , will it have problem or not.
Now, its up to those who complaints to do exactly the same to feedback.
I dont see any since 29 Nov... but , i am very graetful for yoru suggestion. Thank you.
I also have the same problem with an xperia play on 2.3.4.
With data disabled, which is how I want to use the gps, I get frequent loss of signal which makes the navigation useless.
If I allow a data connection, the gps work reliably. The only way I can get a reliable gps function without data enabled is to disable internal gps and use an external gps receiver. This is not convenient but it works. After testing extensively my instinct told me that this is something to do with attempts to contact agps. But unfortunately you cannot disable this, though of course turning data off should disable it.
I did the same.
I took back my old BT external GPS from retirment ! and it works.
Mismo problema con un Xperia mini pro con android 2.3.4 y compilación 4.0.2.A.0.58 de Vodafone, la conexión de GPS se pierde cada 5 minutos durante 30 seg. ¿hay ya alguna actualización de Software que lo soluciones?
Same problem with Xperia mini pro, android 2. - 4.0.2.A.0.58 Vodafone branded. GPS signal is lost every 5 min. during 30 secs. Any solution or software updates?
Thanks
Me too, same problem on xperia Neo, only with 2.3.3 and 4.0 firmware and 2.3.4 with the last firmware
this not happend with 3.0xxx firmware
i have no data connection, and i don't use agps to fix
but the problem is still here
if i run Gps status i can see the signal drop costantly, it is no clear
in a moment i get 10 satellites, after that 1 only, and then again 10 in a fraction of a second
you can see the bars of level disappear and reappear immediatly
i don't know if is the same problem, but there is
Hi JojoNeo,
I'm working with GPS at Sony Ericsson.
This is probably caused by a problem in the APN/data connection settings.
Please let me know which operator you're using and in which country.
Please also list the APN and APN type settings available in your phone.
Settings -> Wireless & network settings -> Mobile networks -> Access Point Names
Example from my phone:
Country: Sweden
Operator: Telia
APN 1: online.telia.se
APN type 1: default,supl
APN 2: mms.telia.se
APN type 2: mms
I would also like to know if the data connection status icon is showing in the status bar when this happens.
(G/E/3G/H icon with arrows pointing up and down)
//Oskar
Oh my god, is totally right
in flight mode no gps disconnection !!!!!!
today 20km in the city with these settings:
wifi off - gms only - connection data off (i don't have a sim plane), my cell is totally out of the net
first 10 km gps drops every 5 minutes
last 10 km, same settings but flight mode ON
no more signal drops !!!
i don't know if crying or laughing
but it is clear this is a BUG
please put in evidence this discussion, Sony do something, we hope in you
