I have downloaded the GPRS settings from BSNL, but i could not access the GPRS. Any application if i tap it shows that pls check ur internet settings. kindly somebody clarify this. This is with when i access the APN as BSNL GPRS. But if access the APN as BSNLlive the browser alone works not the other applications like android market etc..
I can help you with the settings with BSNL GPRS South Zone.
Got to Settings> Wireless Controls > Mobile Networks> Access Point Names
If you find an option named Cellone GPRS, then open it and see that the settings are as given below.
If the option is not found then click the menu button and Add a New VPN named Cellone GPRS
GPRS Settings for South Zone
Name
Cellone GPRS
APN
gprssouth.cellone.in
Proxy
Port
Username
Password
Server
MMS proxy
MMS port
MCC
404
MNC
72
APN type
default.supl
*Note: These settings are for BSNL GPRS South Zone.
If you are not from South Zone or you are unaware of the zone then please go to http://www.bsnl.co.in/service/mobile_gprswap.htm for more details.
Same problem m facing using Reliance-MH network. Browser is working fine but other application i.e. Gmail, youtube, market is not working. Contacted Sony ericsson helpline also but they are failed to resolve issue. They are having only 1 answer for all the network issue cant help.
Also this handset doesnt have option to send multiple messgs.
Download proper internet settings from Reliance.
There is an application named Handcent SMS in the market. If market is available you can download this application. It has numerous features that can be used for text messaging.
In the default messaging application you can send messages to multiple recipients. Do the following for that.
1. Type your message or click on a message received and click forward in the pop up.
2. Now click add recipients.
3. Once any of the contact has been added as the recipient click the menu button where you can see edit recipients.
4. Now select the recipients to which you have to send the message.
http://210.212.215.170:8080/msp/wsm/html/index.jsp
Go to the above link and complete the queries to get the correct internet settings for BSNL.
HI, can you suggest me the manual AIRCEL GPRS settings for Xperia Mini Pro
Thanks in acvance
