GPRS CHARGE
sabino
GPRS CHARGE
Hello people from Sony's support forum, I have a question.
I am from Brasil and my carrier(called Oi ) is charging me for use GPRS(might be EDGE), they have a promotion like that: when I turn on mobile data connection they charge me 0,99 cents per day.  The problem is: i am NOT turning ON mobile data connection(I just use wifi,  i just use mobile data on my 2º phone with another carrier), but they still charging me!!  Then  I have restricted background data, they keep charge me.  Then I install firewall restricting the apps connect internet thru mobile data, but they keep charge me!!!
Is there a way of android exchanging information with the carrier, even if just to say "hello"?
7 REPLIES 7
What if you remove the APN settings and also turn off the data?
sabino
I already did this! Thanks
Did it worked?
sabino
No! did not works, I will file complain against the carrier.
You should, keep us updated
sabino
No updates.  The ZU is the only smartphone that I have had that shows the little letter that refer to mobile data even if the mobile data is off!
What did your carrier/network said about this issue?
