Google Maps problem after ICS update : Xperia Ray
I updated my Xperia Ray with ICS offcial update with PC companion. After the update, Google Maps applicaton is not working as it was before.
01). My location on the map is shown as a blue dot instead of the blue arrow.
02). North up/Track up button is not working.
03). It takes longer than usual to detect my location. (sattelite signals are perfect and recieving from 7 sats)
I have ticked all three options in Settings>Location Services
I have also turned on wi-fi
I updated the app with app store and still same.
I have attached some pictures to this thread.
Please help.
Thank you.
7 REPLIES 7
the reason it's only a dot, its bc you are not moving, but try this
settings -> applications -> manage applications -> maps -> clear data/cache and uninstall updates
restart your phone and then check again
Thank you very much for your reponse. I have uninstalled updates but it didn't help. When I press the track up button nothing happens.
and the arrow is not shown when I move. Slightly_frowning_Face
Nabeel
that arrow is not there,
i checked it on the very first day and it seems to be a problem with google maps
And  have all the same problem as you
i checked everything and wrote about it to google
rajabertie
I'm also having the same problem with google maps in my Ray. This problem must be solved my the Xperia team or by G-maps developers ???
grind_3205
Same problem with my Xperia Active, google maps doesn't work with compass Slightly_frowning_Face any update with this issue?
rajabertie
finally this issues has been fixed by google in the maps ver 6.10 update and get the compass back :smileygrin:
