Have you checked Settings then Sound and notification to check it's turned on for sound etc and as for Gmail, do you have sync enabled and in Gmail app settings you can check to make sure that for that app you have Sounds enabled for notifications
Try an app preference reset - Settings then Apps then tap the option key in the top corners then Reset app preferences then reboot and test checking the settings again once rebooted
Settings OK, still no notification. In KK 444 worked excellently! What should I do?
What about uprgade to Lollipop 5.1? Do you prepare it? Factory reset? Coz there is NO sync on Gmail!!!! I have to sync Gmail manually!
There is sync with Gmail and mine works fine so you either have not done something or haven't enabled a settings or you have a 3rd party app causing a conflict - Your last option if the App preferences reset doesn't work is to perform a system repair
Performing a system repair using PC Companion will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Error 11 modul update? Firewall terminated...
Then you are using a 64bit system or Win8/8.1 and have the M/S driver signing issue, You could try compatibility mode or you will need to use a Win7 32bit type system
no W7 and 32
