Hello People,
I bought a xperia ray from U.A.E, It was working so fine and i updated to ICS ....
When I updated to ICS it shows android has stopped unexectedly , and it shuted down...
And I tried to turn on but it didnt it shows low battery ! ! I tried to change the battery still didnt ...
I TRIED TO CONNECT TO SONY BRIDGE BUT IT STILL DIDNT CONNECT ! !
I THINK MY PHONE IS FROZEN ! ! ! ! !
PLZ HELP ! !
Thanks....
Remove the battery for a few minutes.
Insert the battery.
Phone no turn.
Connect the charger (use original charger and cable).
Charge the phone while turned off for about 5 hours.
If it does not charge additional options:
- try another cable and charger
- try another battery
Do as veresova said
Remove the battery and reinsert it after few minutes
Connect your mobile to wall charger and let it charge for hours
Thanks Nabeel and Veresova...
I tried to do it but no response !
Ooops, now you need to reinstall the phone's software
Open bridge for mac and reinsall/ repair your phone's software
If you have windows PC then it would be much more easier
Here are the steps for Windows PC
________________________________________________________________
SUS ( Sony Update Service) ... download and install it on pc and follow the on-screen instructions http://www-support-downloads.sonymobile.com/Software%20Downloads/Update_Service_Setup-2.11.12.5.exe
or
Both the links are same
Nabeel
As I Told My Phone doesn't connect to sony PCC or Whatever ! ! !
Thanks ! !
Unfortunately you can't do anything more from your side, you will have to visit service center
Did you try to use SUS on Windows PC ?
SUS is best for bricked device
what is sus ?
if u dont mind can u please explain ! !
Thanks ! !
SUS is Sony Update Service as Nabeel said in his reply
U I tried but no responce
