Xperia play - Is it normal that the front-facing camera displays a grayish image? - If this is normal then it is really bad.
it shouldn't be like that
go to settings -> about phone
which android version and build number do you have?
yeah it does on mine too...bt it does so wen there is no sufficient light...or else if u r too much close to the camera...stay a bit far frm the cam...u can get colourful pics
Either way the front facing camera is horrible. Lighting has to be right in order for that grayish color to vanish. I never take pictures with the front facing camera unless I have no other choice.
i also have dark front camera problem ....somebody give any solution :-from MIRO
