front facing camera doesn't work
thtita
after updating my device to a new software, the front facing camera doesn't work anymore. I just see a black screen and it doesn't take any pictures. I tried resetting the phone, did factory reset and everythinh, nothing solves the problem. I'm desperate to get this sorted. Anyone has had this problem before? any solutions about this??
Thanks
2 REPLIES 2
profile.country.RO.title
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
Samer_Othman
same issue and even if i did the rest or repair still not working , btw when i use the camera then i want to chose the front cam it doesnt give me an optio to change it so what is the problem ??!
