hello ... have a problem with the front camera, face recognition lock does not work .. I can not .. I have 4.1.B.0.587 update ... Thank you for your help.
Hi there.
I need to know the exact model of your phone.
But just in case the Face Unlock option is under Settings>security>Screen lock>Face Unlock
Have a good day.
Francis.
Sorry Neo V
Hello there.
The strange thing is that you don't have the Front camera option listed in the picture mode list.
Did you changed the software on the phone?
If you have the Stock version of the Software then try to do a software repair:
http://talk.sonymobile.com/message/316161#316161
But it looks like you have the wrong software on the phone becouse the Front camera is not listed and it's not turned on when you activate the Face Unlock function.
Hope this helps.
Francis.
Thanks for your response contact service will pass ederim.yetkili did not do anything wrong because I'm updating Sony PC Companion 2.1 ..
Have EXACTLY the same problem. Did PC Companion worked for you?
Im facing the exactly same issue, now im on cyanogemMod 10, and any rom that I flashed dont show up the front camera
