Hi, everyone!
Something really weird is happening with my xperia mini pro (sk17a): Whenever I turn the front camera on, WIFI DISCONNECTS!!!!!
It reconnects automatically as soon as I turn the front camera off... Is this a known issue? Is there any solution? Could somebody please help?
Thanks in advance!
Hi, it could be a software issue, suggest you software repair phone with either PC Companion or Update Service. Be aware that this process will erase phone data completely.
Thanks for your quick answer!
I will try your suggestion and report back.
Waiting for the good news ....
I just updated the phone’s software to latest version with PC-Companion. First thing I did when phone restarted was connect to wifi and turn front camera on. No luck. Same problem. WiFi disconnects when I turn front camera on, reconnects as soon as I turn front camera off.................
Any ideas?
Strange that this only happened after turning front camera on .... Can you confirm that?
Oh, yes. EVERY time I turn the front camera on, WiFi disconnects...
(No problem with the primary camera, thou)
Let's go back to basic .... Check Wi-Fi Settings!
Settings>Wireless & networks>Wi-Fi settings>MENU (button)>Advanced>Wi-Fi sleep policy, is it set to Never?
Yes, Wi-Fi Sleep policy is set to "Never".
My next question, did the front camera ever work when you activate Wi-Fi?
