frezee
frezee
hiya just wondering if anyone can help... my experia x10 frezees on me when my memory card is in it but when i take out my memory card it seems to work fine how can i fix this and get it working again with my memory card??
8 REPLIES 8
do you have another SD card that you can test?
i dont will ask a friend...i even tryed upgrading my software on it but same lol
is this a new SD card? has it always acted this way? does your SD card works with another android?
ive had the sd card since i had the phone about a year and a half....  its always worked fine up untill last week when the battery died and  so put on charge  ect and and it went like that guy in voda store said it might b the battery so i went out and bought another battery and still same  none of fmy friends have an android phone for me to try it out on....
try to backup everything and then repair it with
Update Service (SEUS)
http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe
this are other apps to backup
Contacts
open your phonebook
on your computer
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
or your SMS use
"backup & restore SMS"
or for your MMS use "Save MMS"
Call Logs
And for call logs this is great
My Phone Explorer
https://market.android.com/details?id=com.fjsoft.myphoneexplorer.client&hl=en
http://www.fjsoft.at/en/
Markus1
Leader
I suggest you try to repair the software with PC Companion. Update Service will also work but it's recommended to use PC Companion with Android phones.
Also, if possible, try with a different SD card.
