hi there i have a sony xperia p that was given to me from my cousin and he has his face unlock on it and a pin he has forgotten his pin so how can i acsees the phone or how do you hard reset it. thanks guys
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Hi ibzdon.
Here is a link to the PC Companion software that you will use to unlock the handset.
http://www.sonymobile.com/global-en/tools/pc-companion/
I hope this helps.
