FORGOT SCREENLOCK PIN
ColeMCrook916
Can anyone help me with this?
profile.country.RO.title
_alexdon_
You have 2 things to try:
1. unlock without data loss:
/t5/FAQ/How-to-unlock-a-phone-w-o-reseting-reformating-the-phone/m-p/927295#U927295
2. you need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
