FORGOT SCREENLOCK PIN
heyaaxox
i forgot the screen lock password to my sony xperia m i have already tried pc companion it says my phone is not accesible
please please help i really need to unlock my phone:smileyhappy:
Thommo
Genius
Normally when setting up a pin you are asked to enter a security question with answer - If you enter your pin wrong 5 times you should be asked for this answer to the security question - however you may need to perform a system repair, To do that which will factory reset your device and also means that any and all data will be erased - You will have to use either PCC or SUS found here - For PCC unplug your phone from the Pc and fully switch it off - Start PCC select Support zone then Update my phone/tablet then in Blue select Repair my phone/tablet and follow the instructions - Remember that when prompted hold volume down and connect your USB cable - Your phone should be switched off - In some circumstances you may need to perform this twice as the 1st time will install the Flash driver
