Floating Touch in Xperia Sola not working
Hey Guys,
I just bought the new Xperia Sola.  As I understand, the floating touch for Sola works currently both in the Live Wallpaper and Default Browser (For selecting links).  But the floating touch is not working in the browser.  It is not at all selecting any single link.  Can some body help please?  Is this a problem with the phone?  Should I take it to the service center?
14 REPLIES 14
Hey guys!
I figured out some stuff. Floating touch on LWP only works if you use the original launcher (will not work on GO launcher, ADW, Nemus. I tried out these). In the browser, it not work on every site. There are webpages (like facebook) where you can't use it. That's what I know so far. I hope it helped.
mandeep148
R u running Default android Browser,
If yes then go to options then check flouting touch,
if this not work then repiar ur phone with Sony pc campanion..
if not again then last solution is Go to Sony service center..
AJ69
Hey man
If you want to activate the FT on your Sola
Lock the screen then unlock
If you havr a pattern
Try to unlock it by floating
if it unlocked
Now you have activated the FT
To deactivate it
All you have to do is turn the screen of and re.unlock it by old physical touch Slightly_smiling_Face
Tell me what happened with you!
AJ69
AJ69
Have**
