Hi , I got my Xperia U, I finally got a phone with good camera and flash, but problem is everytime i take a picture with flash on, the whole picture becomes white because of the strong flash light. I also tested Xperia P and S flash light but they were working good and took good pictures in dark. I wonder if anyone else has same problem with his/her Xperia U? And how to fix it?
Hopefully this is just a software issue in your case but please do run an update/repair to confirm:
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connection steps
remove the plastic cover from camera lens...
that whitishness is becos of that cover..
